embed hooks container
in the 2 last betas and in the new update.. there's an issue with hooks. seemms theres no next point at the end of embeded hook container.
seems correct when open in segue editor, but not when played.
thanks,
T.
thanks,
T.
Re: embed hooks container
There is never a next cue point in a hook container automatically added or removed.
This has also not changed in the new version, as nothing was changed since many versions.
Can you please explain, where you discover a difference in the latest version with respect to an older version?!
Bernd, there's a misunderstood, when there's a voice track recorded right after the hook container, the next point in the hook container isn't active anymore when played. as it's active in the segue editor
- IMG_1008.jpg (40.67 KiB) Viewed 7646 times
- IMG_1007.jpg (27.38 KiB) Viewed 7646 times
sorry for the reversed pictures... that is weird
The pictures are rather hard to read, as they are also very small.
But what I can see, there is no embedded hook container being used in your screenshot.
However, I guess I now understand what you are trying to say...so I'll do some testing here on my side, if I can spot any issue!
Oki. Thanks.
So as I understand in your case the next cue-point of the hook container is shown in the segue-Editor but not used in the DJ Players.
Just had a test... it's now perfect.. thanks.
